Noisy Clutch posted by CollinBoz on July 13, 2011 at 03:11 PM
popping sound. I believe there's a TSB for early model clutch master rods having this problem. The solution was to grind down the end that pushes into the piston so it doesn't slip. I'm not sure when this was supposed to have been corrected though.
Can you tell if the squeak is coming from inside the cabin, under the hood, or under the car?
